查看: 4203|回復: 0
Bongiovi 汽車音響 這有地方可以試聽嗎? 差異多大?
發表於 2014-8-6 18:02 | 顯示全部樓層 |閱讀模式
本帖最後由 yenru 於 2014-8-6 18:16 編輯
據說是新一代車用音響系統
Bongiovi Acoustics car audio Australia - DPS Available for TOYOTA
Bongiovi 汽車音響
好處是
Benefits of Adopting the DPS Technology
-Low-cost components perform like high-cost components.
-Easily implemented via Digital Signal Processor (DSP).
-Immediately hear significant sonic improvement
–Road noise is mitigated via custom-tuned profile for your vehicle
-Cost savings, using your existing installation
-Reduced weight in the vehicle.
-Frees up vehicle real estate.
-Provides a premium audio solution without costly hardware additions
採用DPS技術的優點
- 現有低成本組件,如高成本組件執行。
通過數字信號處理器(DSP)-輕易實現。
-立即聽到顯著改善音質
- 透過自定義調整的型態替您的車輛減輕公路噪音
-節省成本,可以利用現有的安裝
  - 減少重量的車輛。
-免除了車輛真實空間。
  - 無需提供昂貴的硬體擴充的音頻解決方案
GMT+8, 2025-9-3 08:34 , Processed in 0.056315 second(s), 9 queries , File On.
